CEL mystery
Yesterday, my CEL went off. And the car is not running rich anymore. It really frickin wierd. I know it should be running funny because I dont even have one of the 02 sensors plugged in! Any ideas?
RE: CEL mystery
did the light burn out?
RE: CEL mystery
That would be damn funny
RE: CEL mystery
How do you know that you aren't running rich anymore if your O2 sensor isn't connected?
RE: CEL mystery
Well, the car doesnt shake anymore at all when in idle. It also has a very noticable pickup and throttle response. It almost seems that the ecu decided to hell with it.
RE: CEL mystery
bump?
RE: CEL mystery
I'd say the light burnt out, codes do not fix themselves. Also how did you come to the conclusion it was running rich?
RE: CEL mystery
It friggin runs bad... obviously becaus eone sensor is going "huh?" and the other isnt even plugged in. I will get it all straight once I get the hi flo welded where the test pipe is. By that time there will be two bungs for me to connect to.
If I read in the forum somewhere correct... doesnt the o2 that goes after the cat get the simulator? Or should I do both. |
RE: CEL mystery
ORIGINAL: Remmy doesnt the o2 that goes after the cat get the simulator? How long have you been driving it like this?? :eek: |
RE: CEL mystery
does it still illuminate for those two seconds when the key is first turned, (for the burnt bulb theory)
