HondaCivicForum.com
-   -   CEL setting ECT Water temp and VTEC pressure valve codes (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/cel-setting-ect-water-temp-vtec-pressure-valve-codes-59797/)
jtyoder Jan 28, 2008 11:25 AM
Did the paperclip jumper trick to read CEL codes on B16A2 (P30 ECU). Got codes 6 ECT water temp sensor & 22 VTEC pressure valve. I suspect my cold start issue is related to at least the code 6.
Does anyone know where I can find the specs on my water temp sensor? Need to know the expected resistance at given temp(s). Engine is from a 92-95 Del Sol.
