HondaCivicForum.com
-   -   changing cable reel... no red cap (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/changing-cable-reel-no-red-cap-88411/)
Vartok Apr 12, 2011 12:02 PM
I just got my new/used cable reel for my EG in today and went to replace it... removed the side cover to disconnect the plug to the air bag... i remember reading something about useing the red cap to plug one of the wires.... well mines not there... what does it do and is it needed?
also, im doing this kinna from memory... could someone link a how to on swapping it... having a hard time finding it for some reason
WellFedHobo Apr 12, 2011 03:01 PM
I thought the cap was just there to make absolutely sure you didn't blow up the airbag. Just be careful with it and don't point it at your face when you unplug it.
Vartok Apr 12, 2011 03:46 PM
Yeah, I'm doing every thing from the passenger seat... However I hit a snag already... What size is the torx bit that hold in the airbag? My t30 pops out and a t40 is too big.... I'm guessing t35, but I want to make sure before I order it because no store has that size here
Vartok Apr 15, 2011 09:42 AM
found a t35 in a cheap ($3) pit set at big lots... turns out the screw is a t30 >.< went back and tried with the new t-30 bit and got one cracked loose... but the other striped out... suggestions on how to remove it?
WellFedHobo Apr 15, 2011 09:44 AM
Use a dremel or saw to cut a flat groove in it so you can use a flathead. Or, get a flathead and a hammer. Make sure the flathead is just a little bigger than the stripped out hole and smack the screwdriver into place. It might give you enough grip to pull the screw out.
Vartok Apr 15, 2011 09:47 AM
i tred to hammer the t35 in as well as the t40 bit, but either the screw is too hard... or im afraid of braking something with pounding on it liek that... and i thought about the dremel, but using something liek that, that close to an explosive made me a bit nervous
Turtlegrip Apr 15, 2011 11:00 AM
word to that, its not high tech haha but you could epoxy/glue a piece of metal into the groove that is there and when it tries try turning that.
mk378 Apr 15, 2011 11:40 AM
See if you can find a red shorting cap at a junkyard. I think most Hondas use the same one. Put it on then drill out the screw.
