check engine light 93 civic, runs like ****
Old Aug 21, 2007 | 02:04 PM
DRAGUNOV's Avatar
Default check engine light 93 civic, runs like ****
hey guys i have a check engine light code #43 fuel supplysystem
i have a b16 swap, gsr ecu,with cams, intake manifold, a big bore throttlebodie, full exhaust and no cat.
i did a compression check (150psi all 4)and the plugs are pretty black but not wet.
i beleve code 43 would refer to a oxygen sensor problem but the car runs like **** all the time. so i am reluctant to just change the sensor.
any ideas
the check engine light comes on when i floor it
thanks
Old Aug 30, 2007 | 06:12 AM
DRAGUNOV's Avatar
Default RE: check engine light 93 civic, runs like ****
bump
no one has any insight on this?
Old Aug 30, 2007 | 08:51 AM
JimBlake's Avatar
Which GSR ECU? Match to the engine? Fuelmaps for a B18C1 would cause slightly incorrect mixture in a B16 (for example). Then the O2 sensor feedback would correct the mixture, but the ECU should report that as an inconsistency that it didn't understand.
90honda87
Oct 6, 2009 04:36 AM
trent179
24
Jan 27, 2008 07:18 PM
93CivicShaved
Mar 30, 2007 09:46 PM
93CivicShaved
Mar 29, 2007 09:31 AM
dj_ipirate
Dec 11, 2005 06:09 PM
