HondaCivicForum.com
-   -   Check Engine Light - Please Help (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/check-engine-light-please-help-90645/)
therealbrad Sep 21, 2011 03:21 PM
On my way home today my check engine light came on. So I stopped by my local Autozone to get the code and buy the part. He told me something I wasnt suspecting. He couldnt get the code because it was a "Hard" code and their machine only read "Soft" codes. Did I get a guy who doesnt know what hes doing or lazy?
1st: Whats the difference between the codes?
2nd: Do I really have to take this to the dealership to get my code read so I can fix it?
04 Civic Si 80k(today)
Please help.
Thanks,
Brad
droopy128 Sep 22, 2011 09:06 AM
Either hard of soft code, he should able to pull the code. Maybe he don't know how to use the scanner. lol
Hard code = something you need to fix/replace, it won't reset on it own.
Soft code = something that will reset on it own, like getting a evap code where this will usually happen if the your gas cap is not tight, then if you tighten you gas cap and drive a little, CEL will goes away.
