Civic Stalling
ok if you're reading this, your civic is stalling.
i have a 1991 honda civic dx and i tried everything to fix the stalling problem. new head gasket, new alternator, new idle air control valve, new main relay and guess what...no difference. brace yourselves peeps because ive found the problem and it is distributor rotor. the part costs about $15 and is fairly simple to replace. upon seeing it you could tell it was the problem. the rotor was worn down and had a crack in it causing it to not fire properly. after replacing it shes been running like a champ. peeps i hope this helps in some way because it caused me nothing but stress and cash. good luck everyone .......cause thats how i roll |
RE: Civic Stalling
Welcome to the forum!!!
Glad to hear your baby is running. Good job on the post I'm sure it'll help someone out in the future. |
RE: Civic Stalling
[sm=welcomesign.gif] to HCF. [sm=groupwave.gif][sm=groupwave.gif][sm=groupwave.gif]
RE: Civic Stalling
Thanks for the information. I'm sure it will come in handy. Welcome to HCF!!!!
RE: Civic Stalling
well the bright side is that you wont have to worry about what has been recently replaced! :D
RE: Civic Stalling
WELCOME!!!
Ok... I have to ask. Was this accompanied by an ramdom, unpredictable, irrattic idle? |
RE: Civic Stalling
yes there WAS a ramdom, unpredictable, irrattic idle
RE: Civic Stalling
thanks for the info man. i just got new headers and my car has been idoling really low and then it'll stall so im taking it to the shop today to get it checked out/fixed. im pretty sure the o2 sensor is messed up but if its not then ill let them know to check out the stuff u mentioned. thanks again!
| All times are GMT -8. The time now is 04:21 AM. |
