Cluster help...
Hey, yea i recently installed the white layout for my gauge cluster, to do so i had to remover the needles, when i did, all but the rmp workedk, the rpm gauge is slow, sluggish, delayed sort of, is it because its just not sticking? can i try spraying some hair spray or glue spray, to halep make it stick? and also a few days later my speedometer just stopped , i didnt take it a part to see if its just stuck... i really dont want a new cluster any ideas to fix these problems will be appreacated, thanks
RE: Cluster help...
wow, ummm, you weren't supposed to remove the needles... ...I don't know a how-to ways to fix them, it's a make a guess kind of a fix. You'll probably have to get new gauges if you want them to be acurate. Call some auto shops and see if they know can calibrate them for you.
RE: Cluster help...
crap...then whats the right way to get the white layout on?
RE: Cluster help...
just slide the layout on with the needles on, you have to go at an angle.
RE: Cluster help...
well, you are NEVER supposed to remove those needles, they are in exactly the place they are supposed to be, and are very difficult to replace correctly... you might need a new cluster, or at least a tach. sorry bro
