HondaCivicForum.com
-   -   code po 420 Cat efficiency (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/code-po-420-cat-efficiency-83825/)
fatbagger Jul 1, 2010 06:03 AM
I have an 03 civic 1.7 code po 420 cat efficiency?? Help
RonJ Jul 1, 2010 07:16 AM
This code generally means that the catalytic converter is toast. Any other CEL codes? Is the engine misfiring?
fatbagger Jul 2, 2010 05:01 AM
Thanks Ron
Yes it had an intermitant missfire which was caused by the cam position sensor which I have replaced! Since then the Engine has run great! just keeps setting the 420 code occaisionally
RonJ Jul 2, 2010 06:51 AM
Unfortunately, the misfire problem that you have now fixed permanently damaged the cat.
