cooling fan not working! :[ help
HELP! any replys are great.
my cooling fan stopd running yesturday on my 99 civic ex once it gets hot the needle starts raising at a fast rate fluid is fine but the fan wont go on! just startd yesturday.. i hope its a fuse i checkd all the fuses in the engine fuse box n the relays but is there anymore lik under the dash fuse box that i might be missing today i had to run a straight connection fan to fuse box just so it go on cuz i need my car so i hope u guys can help me! thanks |
Thermal switch on the thermostat housing controls the fan. Unplug switch and put jumper wire in the plug. Fan should now run all the time the key is on. If not, check relay and fuse (you've already tested the motor). The relay and fuse are both in the underhood box I think. If it doesn't overheat with the fan jumped so it runs all the time, replace thermal switch. Don't just leave the fan jumped because the motor will wear out prematurely.
under the hood fuse n relays were fine i ran a jumper still didnt work so i was missing a fuse i didnt no that the a/c heatr motor fuse controlled the cooling fan but i decided to check it n sure enuff it was blown so i found the problem after 4 hours it was a 7.5 ahh sucks but good thing is i found it thanks so much for replying tho :]
