crank position sensor
Old Apr 14, 2010 | 10:35 AM
fancygirl68's Avatar
Default crank position sensor
got code 4 have 1994 computer 2000 engine need to know how to wire in ckp found the plug not connected on right side of engine where to from there and how please thanks fo helping
Old Apr 15, 2010 | 03:32 AM
First off, proper grammar and punctuation go a long way in helping us, help you.
Need some more info.. What Year/Make/Model is the car? What engine code apepars on the front of your motor? Did you do the swap or did you buy it like that? Are you running an OBD conversion harness?
Old Apr 15, 2010 | 01:31 PM
1994 civic put in a 2000 d16y8 motor only nothing else changed
Old Apr 16, 2010 | 07:51 AM
S142JZKillaV10's Avatar
What do u need ??
Old Apr 16, 2010 | 02:59 PM
how to wire the ckp in so code will go away
Old Apr 18, 2010 | 04:36 PM
The sensor near the crankshaft on the pulley / timing belt end of the engine (which is called the LEFT side, since it's on the driver's side), is not necessary with 1994 OBD1 controls. You can leave it disconnected or remove it. All the timing sensors for a 94 are in the distributor. The problem you are having is with the distributor.
Old Apr 19, 2010 | 07:57 AM
thanks it has a 2000 distributor though cause the 94 wouldnt match up
denisholden
Mar 24, 2013 05:15 AM
90hatch12167
Apr 15, 2010 04:43 PM
Red_Neck
Mar 22, 2007 12:35 PM
Mario89
Nov 27, 2006 09:31 PM
joshr799
Mar 22, 2006 08:53 PM
