Crank Shaft bolt???
I just went and spent $120 on a decent impact wrench and still cant loosen the crank shaft bolt to change the timing belt on my 2000 civic VTEC. Any suggestions? The impact wrench I bought has up to 600Ft lbs of reverse torque. Help
good suggestion, thanks. I have a good heat gun, I'll try it. Also, I'll try the dead blow hammer. I couldn't believe the impact wrench didn't get it. I have 134,000 m on it, and I know I'm on borrowed time. The timing belt hasn't been changed yet.
Heat gun won't get the bolt hot enough. You will need an acetelyne torch. I tried to heat an axle bolt with a propane torch once and it didn't do anything. Although i used an impact for like 5 sec and it came right off.
