HondaCivicForum.com
-   -   Creaking noise on hard turns (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/creaking-noise-hard-turns-60354/)
Hobo Feb 6, 2008 06:44 AM
97 Civic EX sedan AT.
When I turn hard to the right or left I get a creaking noise, kind of like an old coffin opening.
It seems to be coming from the drivers side suspension area. Doesn't seem to do it unless the car is moving. I looked underneath while someone turned the wheel and it didn't make the noise.
Any ideas? Someone mentioned might be wheel bearings, someone else said maybe control arm bushings.
Try.Fail.Repeat Feb 6, 2008 07:27 AM
RE: Creaking noise on hard turns
my car does the same thing. thought it was maybe the bushins or mybe tie rod ends...haven't figured it out yet. after we had a pretty bad rain here a couple of months ago it stopped doing it, but then it started up again recently, only not as bad this time.
Hobo Feb 6, 2008 08:05 AM
Mine got worse after I went thru some big puddles in the road.
I'm going to jack my car up later today and take a look. I'll post if I find something.
RonJ Feb 7, 2008 06:31 PM
Sounds like a potential power steering issue. Is the fluid low?
Alternatively, when you jack up the front end, inspect the CV boots on the axles. If torn and leaking, the axles may need to be replaced.
macbeth18288 Feb 7, 2008 07:28 PM
I have an 01 civic ex and mine does the smae thing. i had it checked though and they said that it was just normal. Kind of hard to believe though, because as RonJ says, it sounds and feelslike a power steering issue.
Let me know what you find out.
bakertime Feb 8, 2008 06:02 AM
Same problem here...My PS was disconnected for a while by it's previous owner, and I don't think the fluid was was connected. May be PS related...
Hobo Feb 8, 2008 06:51 AM
I checked my power steering resevoir this morning and it was low. I put some in an drove to work but didn't notice much of a change.
98civkmik Feb 8, 2008 02:08 PM
I had the same problem on my old car, and it was the cv boot and i think my dad calle dit cv joint? But after getteing those replaced it didnt make
anymore noises.
RonJ Feb 8, 2008 05:27 PM
ORIGINAL: Hobo
How low was the PS fluid level? If it was very low, then you may need to bleed the system by turning the wheels lock to lock several times. Afterwards, recheck fluid level and top off if necessary. You should also determine whether your PS system has developed a serious leak. By the way, use of anything but Honda PS fluid can damage the system.
Hobo Feb 8, 2008 05:38 PM
ORIGINAL: RonJ
ORIGINAL: Hobo
I did turn the wheel lock to lock a few times. Unfortunately I used generic power steering fluid.
