Crush Washers
Old Jul 28, 2008 | 08:17 AM
import tuner's Avatar
Default Crush Washers
Are there special crush washers that go on the oil crain bolt?
Last time I changed my oil, I got a crush washer from Napa and now my oil is leaking very slightly. It never used to before.
Old Jul 28, 2008 | 08:21 AM
Default RE: Crush Washers
Yeah, just get the plastic washers and replace them every third time you replace the oil. To best prevent leaking, torque the drain bolt to 33-lb-ft.
Old Jul 28, 2008 | 12:00 PM
Firehawk989's Avatar
Plastic washers? Honda always gives me a metal one when I get the oil filter from them.
*Edit* I don't think it should be a crush washer either. Are those the sort of serrated ones? That's why its leaking.
Old Jul 28, 2008 | 12:10 PM
ORIGINAL: Firehawk989
I got plastic crush washers from AutoZone, and they work fine.
Old Jul 28, 2008 | 12:28 PM
chandler583's Avatar
I have the plastic ones, and I didn't know you were supposed to replace them every third time. How much do they cost? I've never had oil leak from the drain plug.
Old Jul 28, 2008 | 12:49 PM
The recommendation is replacing them every third use, but if it is not broke then don not fix it.
Old Jul 28, 2008 | 04:41 PM
babyivan's Avatar
crush washers are what Honda gives you with the filter.... A crush washer is just an aluminum or copper washer that's meant to "crush" into a seal around the drain plug when torqued down, it has nothing to do with being serrated or not(never heard of a serrated washer BTW).
I bought 20 of the Honda aluminum crush washers the last time I was at the parts counter.... it's good to have a stock of them and they are cheap.
Old Jul 28, 2008 | 07:49 PM
^ditto
i bought a thing of 5 honda crush washers on some website for like 3 bucks, i ordered it online because i was already buying some honda shin-etsu silicone grease for my window seals. the plastic ones i have been getting from advance auto parts dont seem to create a very good seal for me.
Old Jul 29, 2008 | 08:06 AM
Thanks for the input guys, I will probably go to autozone and pick some up or order some from hondapartsunlimited.com.
I guess I just figured that the Napa metal ones would work.
Old Jul 29, 2008 | 08:15 AM
The NAPA washers are probably fine but you may be over or under torquing them.
