D16Y8 clicking noise
Old Oct 10, 2009 | 03:42 PM
AnthonyG's Avatar
Default D16Y8 clicking noise
Hey, i'm looking for some ideas on a clicking noise coming from the engine. The car's a 2000 civic VP with a D16Y8 swap. about a month ago i had the valves adjusted, and recently i've been hearing this pinging/clicking noise out of the top of the engine. I figured it may have just been a bad valve adjustment so I adjusted them myself today and found they were loose, but when I started it up, the engine ran better, but the clicking sound was still there.
Here's the link to a vid of the engine. You can clearly hear the clicking over the other engine noises.
http://www.youtube.com/watch?v=uGvcWxjxsaA
Here's the specs on the engine mods:
Engine Block:
- D16Y8 block bored over 0.010 mm (non-sleeved) 1.7L
- .010mm over sized SRP low compression 9.0:1 pistons
Head:
- D16Y8 head (milled .001 mm)
- ported and polished intake and exhaust ports
- Ferrera Valves with a 5 angle valve job
- Ferrera Titanium retainers
- Comp Cams high tension valve springs
- Comp Cams 10500 cam
- AEM adjustable Cam Gear
- Mugen valve cover
Old Oct 10, 2009 | 03:52 PM
pull 1 plug wire at a time and see which cyl. its coming from
Old Oct 10, 2009 | 04:02 PM
My y7 makes the same noise when cold starting. Dunno what the cause is.
Old Oct 10, 2009 | 04:05 PM
AnthonyG's Avatar
So pull a plug wire and start it up and see if the noise goes away and if it doesn't move onto a different plug wire? Won't that burn up the coil or distributor?
Old Oct 10, 2009 | 04:06 PM
AnthonyG's Avatar
Does the noise ever stop? My noise continues even when the engine is warm
Old Oct 10, 2009 | 04:07 PM
no it wont burn it up its only for a min, just unplug 1 wire at a time from the dizzy cap.
until you find out which cyl its coming from.
also when you adj the valves,do you know what your doing? did you use a feeler auge and to the right specs?
Old Oct 10, 2009 | 04:16 PM
AnthonyG's Avatar
Yes I used the feeler gauge and set them to .007 for the intake and .009 for the exhaust.
Old Oct 10, 2009 | 04:26 PM
AnthonyG's Avatar
I unplugged and replugged the wires one at a time from the distributor and the noise never went away with any of the wires unplugged. Any ideas?
Old Oct 10, 2009 | 04:37 PM
then its in the head, maybe a bent valve?
Old Oct 10, 2009 | 05:50 PM
AnthonyG's Avatar
I was thinking it could be that or a bent rocker arm, would that make sense? I appreciate all your help
