D17a2 New 550 rc injector problems
Here's the stats 01 civic d17a2
To4e turbo setup
Intercooler not installed yet
Stock ecu
550cc rc injectors just installed
So I'm having a starting issue I put the injectors in and it floods. I tried pulling plugs and blowin out the cylinders. I kick started it and it ran briefly
Before flooding again.
A friend was running them on his ek jus prior to me getting them and it ran fine it was stock ecu Na build.
I've heard it's a cold start computer issue and there's a fix can someone help clarify. And can a safc or something similar be used to control the injectors if needed to run them until I save up enough for a aem fic or something better ..(got safc's and other stuff like that for sale cheap here so wanna know if I can/should use it temporarily) or should i jus pull them out ..thanks any info would help ASAP
To4e turbo setup
Stock ecu
LOL, the ecu still thinks the stock injectors are installed. Put them back in or tune the car for the current injectors. I know nothing about how to tune 01-05 civics. Piggy backs such as SAFC etc are junk IMO. I think you would have to go with K pro or an AEM standalone system to have something worthwhile.
Raja I figured that much but I've heard that even with an ecu people still run into cold start issues. Something to do with engine temps and the way the stock injectors have pin size air holes to allow better atomization at start up. The rc injectors don't have the same setup so it causes problems. And I've heard there's a sinple mechanical fix but no DIY to explain it. Thanks for the comments.
From what I hear/ read the d17 isn't compatible with hondata. I could be wrong but I'm sure I've read it multiple times now I'm not familiar with it though can someone give some details on it model/version ,features explain
civicexracer
Jun 11, 2009 06:12 AM
dave_57204
Jan 3, 2009 10:17 PM
socalboi
May 4, 2008 09:00 PM
01, 2001, 550cc, aem, build, civic, d17 problems, d17a2, fic, fixing, injectors, injectors flooding, map, rc injectors, timing
