HondaCivicForum.com
-   -   D4 does not light up in dashboard, but all other gear indicators do (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/d4-does-not-light-up-dashboard-but-all-other-gear-indicators-do-95461/)
DaHonDa Jun 27, 2013 10:06 PM
1 Attachment(s)
Dear fellow forum members,
I've just noticed that my dashboard's D4 (Drive 4), which is below N (Neutral) and above D3, does not light up anymore, whether or not I turn on the headlights. All the other gears light up in the dashboard.
So now, when I'm driving (which is usually in D4), I don't see any gear lit up in the dashboard. It looks like the car is turned off.
What's wrong? And how can I fix things?
mk378 Jun 28, 2013 03:16 AM
My first guess would be the bulb has burnt out. So remove the cluster and check the bulbs.
DaHonDa Jun 28, 2013 08:36 AM
mk378,
thanks for your reply.
What is the cluster?
And how do I remove it?
DaHonDa Jun 28, 2013 09:35 PM
Today, I drove the Civic again. D4 was lighting up briefly, and then it stopped lighting up again.
mk378 Jun 29, 2013 07:20 AM
Instrument cluster-- the part of the dashboard with the gauges and lights.
If it comes and goes, see if it can be made to go on/off by hitting the dash near the cluster, or by moving the shifter handle slightly. There is a switch at the base of the shifter handle that controls the lights.
