Dash lights off bulbs ok????? Help!
Old Dec 12, 2006 | 01:14 PM
DaBears2005's Avatar
Default Dash lights off bulbs ok????? Help!
Problem: 3 dash lights are out - high beams, cruise control and emergency brake. All the others work perfectly.
What I've done: Checked each and every bulb in the instrument cluster, confirmed they are not blown. Grounded wire in emergency brake lever directly to frame, still no light. Cruise Control operates, but no dash light. High beams operate, but no dash light.
Solutions? Help please. Thanks.
1995 Honda Civic EX coupe
Old Dec 12, 2006 | 02:42 PM
cderalow's Avatar
Default RE: Dash lights off bulbs ok????? Help!
dash light fuse?
for ebrake, possible bad switch
high beams (if your beams come on) probably bad sensor on switch/dash light, if they don't bad switch
Old Dec 12, 2006 | 04:08 PM
Dash light fuse: wouldn't other lights be out, like seat belt, choke, trunk, etc? that isn't happening.
Ebrake switch: bypassed switch, still no light.
high beams: beams come on for sure and bulb is a new one.
Thanks, help!
Old Dec 12, 2006 | 10:34 PM
Dr Talon's Avatar
Bulbs blown? Remove cluster, replace bulbs (12 volt common type bulb from any hardware store), try lights with cluster out of dash, if working replace cluster into dash
Old Dec 13, 2006 | 05:28 PM
Dr. Talon, thanks for the response but if you actually read my original post you would have known I already stated I tested and replaced each and every bulb in the instrument cluster, yes even with ones from the hardware store (#24 and #74 to be exact). This is beyond bulb and fuse minor league stuff, this is electrical gremlins.
Old Dec 14, 2006 | 08:54 AM
cderalow's Avatar
check wiring continuity?
Look for possible loose connections/torn wires etc?
mikedahammer
Jan 16, 2014 04:37 PM
itzcorky
Nov 13, 2013 06:26 PM
itzcorky
Sep 21, 2011 07:45 AM
alextoader
19
Jul 6, 2007 04:27 PM
Act of God
Jan 20, 2007 04:53 PM
