HondaCivicForum.com
-   -   Dashboard light dont work. need help (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/dashboard-light-dont-work-need-help-57221/)
Mj96civic Dec 14, 2007 02:03 PM
I took out my radio, put a new one in. It got dark, so i turned on my headlights, they worked, but my dash lights didnt. What the deal? I adjusted the dimmer knob and nothing happenend. What could be the problem?
ugh3012 Dec 14, 2007 02:19 PM
RE: Dashboard light dont work. need help
check the fuse. I am not sure which one but it is printed on that little door.
RonJ Dec 14, 2007 02:54 PM
Yeah, as ugh3012 says, first check fuse #30 in the under-dash fuse/relay box.
If the fuse is fine, then determine whether the dimmer switch is bad by performing the test described in the picture.
http://img339.imageshack.us/img339/3...ure0065tg3.jpg
Mj96civic Dec 14, 2007 05:56 PM
yeah i fixed it. it was a fuse
mk378 Dec 15, 2007 08:13 AM
Make sure all the wires in the radio harness are taped up and insulated. One of them is the lighting wire; if it touches ground the fuse will blow again. This wire may not be connected to the radio but it still needs to be insulated so it can't short out.
