Driveshaft gap between inner joint and differential.
My left driveshaft snapped out due to left lower-ball-joint failure. No problem, bought another driveshaft and ball-joint and reinstalled them, and yes it is the exact same size of driveshaft, i measured every portion of the driveshaft. After putting it in...i get a differential leak. So i take it off again put it in...and i notice there's a gap between the differential and the inner joint of the driveshaft. What can it be, missing oil seal or something?
Here's a photo for better understanding:
-uploadin-
Thanks!
-uploadin-
Thanks!
I did the waiting, 3 or 4 days.... still leaks, but again is there is no additional seal that goes in between the differential and the inner joint spline portion? How can i tell if the differential seal is damaged? All i know there's two seals on the spline itself, and both are located before the set ring. The two seals seem to be at a lower level than the spline grooves...is that usual?
There is definitely an oil seal inside the transmission where the axle splines insert. You can't see it with the axle installed. To see it, you would need to remove the axle and peer into the hole in the transmission.
97' Civic - Manual 5 Speed
About two hands big splat of oil every day or more...
Yes you are right, there's nothing inside the differential spline insert hole.
Thank you so much RonJ for all of your support!
Hopefully i can find accessories like that somewhere...at the transmission stores...?
