dropzone coilover help today
Old Mar 17, 2007 | 12:33 PM
94civicproject's Avatar
Default dropzone coilover help today
hey guys, of course tech help at dropzone is closed today(saturday) and im having some issues..........heres the problem. I bought the DZ coilover set and new DZ strut/shocks. When i slide the alum sleeve over the new shock it doesnt slide all the way down to the spring seat, just short near the weld. Should the sleeve slide all the way down? not sure how to post a pic........any help would be great.
Old Mar 17, 2007 | 12:39 PM
Powermidget's Avatar
Default RE: dropzone coilover help today
Im not real familiar with the dz kit but i would imagine you want it to sit flush(had vspec coilovers and they sat flush with my shock)...maybe its upside down or the weld is sticking out a little to much and you should file it down...hope someone comes through to help you out some more
Old Mar 17, 2007 | 12:43 PM
http://www.madracingconcepts.com/coi...rs_install.htmthis is an instuction set for dropzone coilovers hope that helps
Old Mar 17, 2007 | 01:57 PM
thanks but i have the instructions and of course the pic doesnt show it seated on the spring catch, i will try filing it down some.....i tried to add the pic
[IMG]local://upfiles/19453/CCBBED14479842EB8B8606E731E38D42.jpg[/IMG]
Old Mar 17, 2007 | 02:09 PM
here is my project 1994 civic coupe........
[IMG]local://upfiles/19453/4D557716C0D44257AE64E2393F39071D.jpg[/IMG]
Old Mar 17, 2007 | 03:18 PM
did these shocks come with the coilover...it may be that they arent the correct match for each other...if you can post some more pics of the shocks and sleeves ill try and help you out more
Old Mar 17, 2007 | 10:11 PM
i used a desktop wheel grinder to shave down the welds some and the sleeves sit better. the back ones sit fine but the adjusters sit in the oem lower sleeve, put one side front and back on and looks good, i will take more pics sunday and post them, thanks Powermidget.........this was the auction picture.......
[IMG]local://upfiles/19453/563BC79D25754F2B9AE733CB42DA779D.jpg[/IMG]
Old Mar 19, 2007 | 12:58 PM
well it looks like the front ones dont sit totally flush so you prob just want to get that locking ring under there and just tap it on tight with a ball end...the weight of the car might help....did you notice if they sat better once you put them on?
Old Mar 19, 2007 | 01:03 PM
StifflersMom's Avatar
Cat Fuсker
mine were the same way....never had a problem
Old Mar 19, 2007 | 07:22 PM
they sat better, think i got that problem fixed, now i have to figure out the right springs, they were sent with the wrong description, (front/rear) now i have to redo 2 of them after i get the bolt i broke from honda. 94 from MA, not too bad to only break one. thanks for the help........
colby_666
18
Dec 18, 2009 05:43 PM
southaflow
Aug 21, 2009 07:57 AM
94civicproject
Mar 21, 2007 10:50 AM
devney
Dec 29, 2006 03:00 PM
dmsteele92831
Oct 20, 2004 03:17 PM
