Emission question...
Old Sep 14, 2007 | 02:50 PM
burnindesirez02's Avatar
Default Emission question...
I don't know how many of you are aware of emission tests because of where you are located... but if you do know...I have failed mine badly... My HC is supposed to be at .8 and i was running at 3.59... My CO supposed to be at 15.00 i was running 93.50. Does anybody know what problem could cause this? I just changed my air filter, Spark plugs and distributor cap and i am going to try to take it to a shop tommorrow b ut i was wondering if any body knew. Also i found a thing at AdvanceAutoparts.com called a Ignition Fuel Vapor Canister..Does that have anything to do with emissions? Thanks
Old Sep 14, 2007 | 08:00 PM
cyberx32's Avatar
Default RE: Emission question...
catalytic converter and maybe oxygen sensor
Old Sep 14, 2007 | 09:13 PM
civic_burns_all's Avatar
it has to do with your catalytic converter
Old Sep 15, 2007 | 08:15 AM
Ok..I know its not my o2 sensor because i just read my trouble codes and nothing came up and also my Engine lights not on...so its the cat? any other thing might have to do with it? maybe PCV valve? thanks.
Old Sep 15, 2007 | 11:40 AM
AgentofDarkness's Avatar
If your car is OBDII, you would for sure have a check engine light if the cat was blown. If you havent' changed air filter, fuel filter, plugs, wires, cap, rotor in a while I would go ahead and do that. That could be causing the problem but those are all items that need to be changed periodically anyway. For the O2 sensor, try to get a scan tool that can look at live sensor data. Look at the primary O2 sensor. The primary O2 sensor controls the A/F ratio so if this is not working properly then your A/F will not be correct and this could lead emissions problems. Also check your PCV valve and EGR valve. EGR valve is pretty easy to check. At idle, push the diaphragm of the EGR valve. This will allow exhaust into the intake. Your engien should start to run rough. This means that it is working. For the PCV, pull the valve out and shake it. If you hear a rattle, then it is fine.
helplessboy
Aug 2, 2009 08:42 PM
Civic Si 00
19
Jan 21, 2008 01:54 PM
prelic
Aug 3, 2006 10:56 PM
gsumano
Mar 11, 2006 08:25 PM
dystopia
Jul 15, 2005 02:16 AM
