Engine Not Hot...Please Help Fast
Old Jan 25, 2008 | 02:26 PM
brinriha's Avatar
Default Engine Not Hot...Please Help Fast
Hey forum,
1993 Honda Civic LX 4dr 1.5 Auto
I have a problem. Here it is.
I have very good Heat!!!!
NEW thermostat
NEW Sensor that goes into the thermostat housing (I think temp switch)
Professional at shop cooling system flush
Engine is not heating up to normal temp
Upper Hose to Block gets hot
Lower hose to thermostat housing is Cool or cold.
Please help
Thanks
Old Jan 25, 2008 | 03:16 PM
Default RE: Engine Not Hot...Please Help Fast
Could be working normally except the gauge doesn't work.
Locate the temperature sender screwed into the head beneath the distributor. It is the smaller one toward the back of the car, with one wire. First, is the wire plugged in securely?
If so, proceed to the next test where you'd unplug the wire and ground it. Then turn the key on and the gauge should go all the way up to hot.
If that works, check the resistance of the sender with the engine apparently warmed up. Should be about 80 ohms more or less. Or finding the gauge working, just replace it.
Old Jan 25, 2008 | 03:19 PM
brinriha's Avatar
I will try that but would that explain why the upper hose gets hot and the lower one is cold/a little warm though?
I don't get this at all.
Old Jan 25, 2008 | 03:28 PM
Water flows from top to bottom thru the radiator. So it goes in hot and comes out cold.
The switch on the thermostat housing is sensing the temperature of the water leaving the radiator / about to enter the engine. When the radiator is unable to reject enough heat (due to no air flow), the water in the lower hose starts to get hot. This activates the fan.
general23cmp
Dec 20, 2008 10:43 PM
Onejediknight
Dec 7, 2007 09:07 AM
vtec02
Apr 30, 2007 11:53 AM
mill$civic
Sep 22, 2006 10:33 PM
the_reptilian
Jan 16, 2005 05:15 PM
