Engine Runs too RICH
Basically my 1990 Si is running too rich. The exhaust pipe is very black and the plugs are moderately so carboned up. It is a 1.5L MPFI with stock intake, running about 40psi, new fuel filter, intake was just cleaned with TB cleaner. It is not putting out any codes. It still gets great MPG ... etc. I don't know what else to check. The ECU is a chipped Integra unit. Someone did mention that I should stick with an Si or PG6 ECU mine is a PM7. Could that make it run rich? O2 sensor is brand new..
pretty much what you said:
"The ECU is a chipped Integra unit. Someone did mention that I should stick with an Si or PG6 ECU mine is a PM7. Could that make it run rich?"
that is not stock, right
Do you have to pass emissions ??
scottdh20
Nov 24, 2007 07:50 PM
