engine will not turn over
Old Sep 30, 2008 | 05:30 PM
jeffskw's Avatar
Default engine will not turn over
I just got a 91 civic that a towing company got a few years ago . My brother has had the car and cranked it periodicaly . Someone has gotten in the car and stolen some relays and the converter off the exhaust . When i go to start the car it doesnt do anything . the lights are on on the dash but that is all . I have found a 4 wire relay gone under the dash that goes to the starter and there is a seven wire one gone also . Both are under driver side dash . Everything in the car seems to have power on it except for the stereo . Can anyone tell me what these relays are called so i will know what to look for and ask for. I can get wire colors from the plugs that go to them if needed .
Old Sep 30, 2008 | 07:09 PM
The 4 wire relay if it's way up high near the clutch pedal is the starter interlock. That's why it won't crank. The 7 wire one right above the hood release handle is the "main relay". It controls the fuel pump and injectors, so the engine won't run without it.
Edit: Also check if the ECU (engine computer) has been stolen, it is on the interior side of the firewall under the carpet where the passenger's feet would be.
Old Oct 3, 2008 | 03:58 PM
jeffskw's Avatar
All i can see missing is the two relays . The ecu is still there,thats the first thing i looked for after seeing the relays gone. Thanks for the help. I will see if that does the trick.
rrmallis
Apr 12, 2012 07:32 PM
BrownRice
Mar 6, 2012 04:56 AM
youngfreshwun
Mar 30, 2010 08:40 PM
drumforever
May 28, 2009 06:18 AM
lasombra
15
May 19, 2009 10:55 AM
