HondaCivicForum.com
-   -   Engine wont turn over (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/engine-wont-turn-over-52690/)
96dx4door Sep 25, 2007 03:31 PM
The other day i was leaving work and my car wouldnt start. All of the dash lights and radio work and the fuel pump engages.I can pop the clutch and push start it or start it using the starter solenoid but using the key inthe ignition does nothing but turn the accessories on.I've already changed the neutral safety switchunder the dashboard so i'm ata loss here.Any help would be greatly appreciated!
Sean
RevHardCivic Sep 25, 2007 04:29 PM
RE: Engine wont turn over
mm I'm guessing its the ignition switch... my jeep done the samething[:@]
96dx4door Sep 25, 2007 04:41 PM
where is the ignition switch located? Is in the steering column or somewhere in the dash area,and is it something that i canrepair myself. (i'mpartially mechanically inclined)
foress_89 Sep 25, 2007 04:47 PM
The ignition switch is the keyswitch
96dx4door Sep 25, 2007 07:10 PM
well there's something i should have known...i appreciate the help!
mk378 Sep 25, 2007 08:24 PM
There is also a relay involved with the clutch pedal switch, but check the ignition switch first since it's a lot easier to reach. Also if there's any sort of anti-theft system it could be flaking out and disabling the starter.
