07 Civic MAJOR TUNE-UP
Wife has an 07 with 130K miles.
I want to do a major tune-up, as much as I can possibly do.
I'll do the usual.... oil, air filter, spark plugs.
What else is there to change?
Where is the fuel filter located?
thanks !!
thanks !!
If you haven't before, change the coolant, belt(s), transmission fluid, and the brake fluid. (Hopefully your transmission fluid isn't still that which came with the car).
I don't think the fuel filter is routinely serviced on later models. It's only an issue if it gets clogged by ingesting some dirty gas.
Maintenance Minder | Maintenance Schedule | Honda Owners Site
the fuel filter is inside of the fuel pump located inside the fuel tank.
Kurous
09-14-2007 08:41 PM
cruzncivic
01-28-2007 09:03 PM
