Evap purge valve connector: 4 volts?
Old Nov 28, 2011 | 12:32 PM
ssewall's Avatar
Default Evap purge valve connector: 4 volts?
1999 civic EX coupe
Here's the history report:
-Getting code p1457: leak near evap canister.
-Found the vent shut valve was bad, replaced, worked great for about 3 weeks, then p1457 again.
-Retested the new vent shut valve, it was fine.
-Tested the purge valve using the methods illustrated in the factory service manual, it won't open while engine is hot and rpm > 3500. Actually it won't open regardless.
-Removed Purge Valve, bench tested it with a 12v battery, the valve opens!
-Tested for voltage between the two pins on the connector for the purge valve, there was voltage, but only 4 volts.
So now my question, is the valve supposed to open with only 4 volts, or do I have a bad ground somewhere?
avti960
Oct 18, 2012 08:41 AM
ripper73
Oct 18, 2012 08:38 AM
joelmatt89
Jan 29, 2009 08:39 AM
CiViCeXB
May 2, 2006 12:07 AM
hypnotixcrx
Feb 27, 2005 10:56 PM
