EXTREME GAS MILEAGE ISSUES! HELP!!
Old Jul 10, 2006 | 01:06 AM
  #21
AgentofDarkness's Avatar
Default RE: EXTREME GAS MILEAGE ISSUES! HELP!!
The second O2 sensors tells you if the cat is working properly, so if you don't hvae a code then your cat is prolly fine (you have OBDII). As for the other sensors, if there isn't a CEL then they should also be fine. In OBD II you will have a check engine light if there is anything that will cause your emissions to go up or anything wrong with your engine. $70 to check a CEL is way too much, AutoZone does it for free. Also check the Long Term Fuel Trim (LTFT) with the scan tool, if the fuel trim is above 10% it sets a code, but if its around 8 or 9 that will not set a code but it could cause fuel economy problems.
Old Jul 10, 2006 | 06:09 AM
  #22
96civicex2006's Avatar
The $70 was not just to check the code, but for the machine, and the labor for troubleshooting the problem for the 1st hour (minus any parts of course!!)
-I'm not familiar with the LTFM. What is that and how does it work?
-I actually got a CEL yesterday. I will get the code checked and post. I'm afraid it will be the same general code I received last time, (System too rich/too lean. Bank 1.) How broad and vague is that, huh??
Old Jul 11, 2006 | 02:41 PM
  #23
bmp...
Old Jul 11, 2006 | 03:21 PM
  #24
fglaustin's Avatar
someone may be waiting on the results of what was determined from the cel being on.
Old Jul 13, 2006 | 11:37 PM
  #25
regnumirae's Avatar
do you ever smell fuel after you start it ?
Honda_rookie
Sep 9, 2008 11:50 AM
TonyT
Feb 14, 2007 08:21 PM
bensminger2003
Jan 13, 2007 10:41 PM
tennguy20
Mar 31, 2006 06:26 PM
iNTRuDeR
Jun 19, 2004 11:05 PM
