Fan starts automatically with car start
Hi everyone,
I just joined this forum. I recently bought a Honda Civic 2002 or 03 with EX model. I have a question. Whenever I start the car, the car fan starts automatically. Not the AC but the fan only. I tried to take the fan nob all the way to the left but doesn't help. Is it automatic? or how to control it? Thanks in advance.. |
Probably the power transistor is failed shorted. Or it could be a bad control panel. Do the other functions work, like the knob that selects where the air comes out?
...knob that selects where the air comes out?
This works. AC works. The fan stops when I turn the car off. Is it because of the car climate control or anything like that? |
Are they major problems? how much does it cost to repair them if I give the car to a mechanic?
thanks |
Take the glove compartment out of the car and locate the power transistor it's mounted in the duct and has a 4 wire plug. Unplug it and test ohms between the two pins that have big wires on the plugs, should not be short circuit. If it is replace.
Usually they fail open-- so the fan never runs, it's possible that happened to your car then someone hotwired it to get the car sold instead of paying $60 for a new transistor. Make sure that the fan does NOT run with the transistor unplugged. (Turn key off before plugging or unplugging). There's a relay under the hood that cuts power to the whole circuit when the key is off, that is apparently working is why it stops when the key is off. The control panel uses the power transistor to vary the fan speed (according to the driver's choice with the knob, it's not automatic) or stop the fan entirely when the key is on and the knob is at "0". |
Hi,
I am afraid that I would not be able to test the ohms etc (as I am not so confident myself) in doing so. So,if I need to get it fixed will I need to spend $60 ?? also let me know if it is a major problem. Thanks |
Can someone please answer to my last post...its pretty important to me..
The part (power transistor) lists for $60 at the dealer. Of course if you have a shop work on it, you'll have to pay labor. On the outside chance that the problem is actually the control panel, that part lists for $230.
Thanks a lot for the replies. I will keep you posted and check out a few mechanics to get a good deal...
Do you think this is a major problem?
| All times are GMT -8. The time now is 02:20 AM. |
