F'kin o2 sensor
so,
my check engine light has been on forever,
and i got the code,
it was my o2 sensor so i bought a new one,
and i can get the old one out,
i've tried letting it cool down,
trying right after running engine for a while [while hot]
every spray i could find,
and wrench to get best leverage...
this ting won't come out,
and it's starting to strip from me trying...
any tips on getting old o2 sensors out of civics?
[it's a '95]
and i got the code,
[it's a '95]
you need the special socket because it has a slit in it to allow for the wire to pass through it
Did you cut the top of the old sensor off to be able to place a socket over it? Either way, use a high quality 1/2" socket and a breaker bar. You can get a breaker bar from your local auto parts store.
No, if you use a socket to remove it, you need the special tool. otherwise, you remove it while the mani is hot so the metal has expanded. and just use a short piece of scrap pipe and attach it to your wrench or ratchet. This is a breaker bar:
