Flasher dont work at all 91 SI HB
Heya i just buy a Honda Civic SI 1991 HB for cheap and all flasher dont work at all no hazzard nothing happen when i turn right or left
anyone one got an idea about what its can be?! |
RE: Flasher dont work at all 91 SI HB
I am thinking that you have already checked the fuses. Have you checked the relay. I am not sure how you can tell maybe someone can has a way. The dealership or parts place usually will be glad to help if they know you are going to buy it.
your flasher is down in yer fuse panel...
i think its even marked on the cover... don't go to the dealer. get one from a junkyard or someone u knwo with an old civic (doesn't have to be an SI, prollydoesn't even need to be the same year... i can't imagine flashers change at all.)..replace it yourself it'll take like 30 seconds. |
Yeah you can go to a junk yard and get one. I am not sure how much one will cost but if it isn't too much I would rather get one new. I don't think there would be much price difference but that would be my preference on a part like that. If it is a big difference then maybe I would go to junk yard.
If you just bought the car, check the plug behind the hazard button, if that is unpluged or broken, nonew of your signals/hazards would work. check that and good luck.
ORIGINAL: mikezcdx If you just bought the car, check the plug behind the hazard button, if that is unpluged or broken, nonew of your signals/hazards would work. check that and good luck. |
