flat head stud bolt alternator stuck!
Old Apr 24, 2007 | 02:32 PM
frankumar's Avatar
Default flat head stud bolt alternator stuck!
I have a 1994 Civic LX and have been trying to take off the alternator for the past two days. The adjusting fan belt bolt is off and the pivot stud nut also but we can't get the pivot stud out and what makes it even harder is the non-standard flat head on the bolt. We've moved the alternator up and down, put lots of penetrating oil, banged and pryed on the end of the stud bolt, all to no avail. We thought of taking the two bracket bolts out but one is inaccessible unless you take the alternator out. Does anybody have a clue as to how to take off this stud bolt out. Any help is very much appreciated.
Old Apr 24, 2007 | 04:12 PM
hatch46580's Avatar
Default RE: flat head stud bolt alternator stuck!
i know you dont want to hear this but i had the same problem a few years ago i used a punch with a 3 lb sledge hammer didnt work, i used MAP gas didnt help, i tried everything, i had to actually break the part of the altenator were the bolt runs threw to change out my bad alt. Good luck man
Old Jul 26, 2011 | 04:45 PM
drellim's Avatar
How did you brake that part of the alternator what tool? Did you just brake it with a pry bar?
Old Jul 26, 2011 | 04:49 PM
drellim's Avatar
I'm hAving the same problem that bolt is a bitch Im sick already
TPRCIVIC
Feb 2, 2014 01:38 PM
stylincompact
Apr 3, 2007 06:53 PM
knfdeals
Mar 28, 2007 09:48 AM
Carlz0r
Dec 15, 2006 12:26 AM
Jippo99
Mar 22, 2005 07:00 PM
