foglight lamp and switch install
Old Jun 23, 2013 | 03:34 AM
cameraman1107's Avatar
Default foglight lamp and switch install
Any body have any oem lamp/switch install experience? I want to get factory fogs, and don't want a non oem switch/lamp install.
I guess what I need to now is- do I need to buy the oem switch, disassemble the column and install the new switch, remove the facia and install the lights; or is there "a better way?"
Old Jun 23, 2013 | 06:07 AM
What year Civic do you have?
Old Jun 24, 2013 | 05:43 PM
Thank you for chastising me; my bad. I used to be on the M5 board, and an e39 is an e39 is an e39. I have a 2010 4 door silver civic, and it's a budget low level base model and has an automatic transmission. I t has grey cloth interior and I don't know what else I need to say.
Now, I'm assuming they all have the same wiring harness from the factory; they all don't have all the switches and fog lights installed. Want fog lights- remove the switch, replace with correct OEM switch. Remove the facia in the bumper install OEM lights and plug an play. Am I right? Thanks for the help!
Old Jun 25, 2013 | 05:05 AM
I don't know about the 2010, but older models typically had different wire harnesses for the base model vs loaded-- so upgrading was often not a simple plug and play because the wires were not there. Look in the front area and see if there are indeed unused plugs for fog lights.
sde780
Apr 25, 2008 06:27 AM
jhsplaya08
Oct 9, 2007 06:34 PM
my05civic
Jun 7, 2007 07:45 PM
jonyg98civicex
Mar 4, 2007 03:25 PM
my05civic
Mar 3, 2007 03:04 PM
