front end vibration
hello again everyone, looking to solve a new problem today. The 93 has a godawful vibration in it on the drivers front. There is no plat in the tire left/right oe up down. Brakes look smooth and clean but the drive shaft has a little play but I am not sure what normal should kook like. The boot is not torn. When I test drive it and park, the wheele is smoking hot. Could it be a bearing?
Any help would be great. Thouble shooting in Va |
wheel bearing indeed or your brake caliper is stuck
I swapped out a bad tire checked out the breaks and rotor, they look good. Now its just a slighter vibration. It breaks smooth turns good (no squeeling or thumping. Maybe a good balancing will do?
If it gets "smoking hot", the brake is probably dragging. Any play at all in the outer CV joint is bad.
| All times are GMT -8. The time now is 04:03 AM. |
