fuel injection upgrade
Old Mar 29, 2014 | 09:46 AM
David_S's Avatar
Default fuel injection upgrade
I have a 1990 honda civic with the d15 engine out of a 96 (or at least thats what the seller told me it was out of).
I am currently using the intake out of the original engine. I want to use the intake that camee with the 96. Do I need to change the computer? If so what computer do I need ?
If this intake won't work then is there a combination that will?
Old Mar 29, 2014 | 10:26 AM
Search for DPFI to MPFI conversion. Most people use an OBD1 computer from a 1992 to 1995 because it is simpler than the OBDII system introduced in 1996. If your manifold has a 2 wire IACV it should be compatible with OBD1. You will still need to replace the distributor and several other parts.
I thought all the 1996 up had a D16 engine.
Old Mar 29, 2014 | 12:53 PM
David_S's Avatar
Actually the IACV was leaking colant last night which is what started me into thinking of doing the swap while I am fixing that.
Old Mar 29, 2014 | 01:15 PM
David_S's Avatar
The engine that was in the car originally was a D15 B1 4610771. Don't know if those last #s mean anything. Will get the code off the current engine as its currently broken down at work.
The engine in the car is a D15B
Old Mar 29, 2014 | 02:45 PM
D15B with no last number was a JDM engine (originally sold in Japan).
oelhayek
Jul 17, 2007 11:37 AM
bluetick14
Oct 25, 2006 02:19 PM
Flaca14
Jul 10, 2005 01:03 PM
Flaca14
Jul 10, 2005 12:49 PM
SNIPRD
Jan 4, 2005 09:50 PM
