fuel pump...??
aye guys i have a 1991 honda civic sedan...i was just wondering does anyone know where the fuel pump is located..i've checked under the back sent and pull it out but i wasn't the fuel pump.. it looked like the fuel level'er thingy..or is it located in the gas tank.. can someone please help me & tell me what kind or where is the fuel pump located.cuz my civic cranks but it wont start and every one i asked said its the fuel pump..
For a brand new one, it'll probably run you somewhere between $40 and $80, depending on where you shop. I really don't know that well, since all of my parts come wholesale. I would recommend just replacing it with an O.E. Bosch or something. You don't need to upgrade it.
Aight man the no start could be a hge humber of issues. on mine it was a combination of things here is a short list of things you need ot check fbefore shelling out 125 for a pump.
Main Relay
Fuel pump relay
fueld pressure
fuel pressure regulators
Fuel pump main relay
Colgged injectors
Throttle blades
TPS
ignition timing
spark plug gaps
spark plugs
distributor cap
rotor button
wires
it could be any one or a combinanation
on mine it was
spark plug gaps and fueld pum main relay
in my foredns it was the throttle blades and the ignition timing and the regulator so it can be a number if things so chekc these and see whats up
Main Relay
Fuel pump relay
fueld pressure
Colgged injectors
Throttle blades
TPS
ignition timing
spark plug gaps
spark plugs
distributor cap
rotor button
wires
on mine it was
wkhan69
Aug 9, 2009 10:08 AM
rbsterli
Feb 28, 2005 07:17 PM
JrscCivic00
Jul 1, 2004 02:32 PM
