Fuse Trouble
Old Jun 12, 2012 | 10:13 PM
GrzzlyAdm's Avatar
Exclamation Fuse Trouble
I bought a 1996 Honda civic Dx a few months ago and it already had fog lights installed, The lights appear to be directly spliced into the running lights and about once a week the fuse for them blow. My first thought was that maybe the fogs lights were pulling to much power for the fuse so i upped it to 25 amps but it blew again tonight. I'm unsure if it is the way the fogs are connected is the problem but i can't think of anything else. Any Ideas?
Also, I plan on re-wiring them later this week but if there is an easier way I want to know.
Old Jun 13, 2012 | 04:28 AM
Don't use larger fuses. With that said, if you're blowing 25 amp fuses, there must be a short to ground somewhere.
The stock wiring in a Civic is rather thin and made only to support the stock parts. So re-wire with a relay and a direct (fused) feed from the battery.
Old Jun 14, 2012 | 11:13 AM
GrzzlyAdm's Avatar
Thanks. I rewired everything and it seems okay. Running lights worked fine last night.
864DRCivic
Jan 23, 2021 06:19 PM
CatsnotCars
Jan 28, 2015 12:24 PM
IMPORTEDCONCEPTZ
Dec 10, 2006 09:46 PM
mitsuman57
Feb 26, 2005 10:04 AM
Magnum
Oct 8, 2004 10:28 AM
