Gasket under rocker assembly
Newbie needs help... First, this is a great forum!
I need help trying to get my message across in getting the correct part, or where to go to get it. :confused: I have a 1990 Civic LX 4 door sedan with over 150,000 miles and still runs like it was just driven out of the showroom. I have a leak in the spark plug tubes. I purchased the Valve Cover, Grommet and Valve Tube seal kit. HOWEVER, I know that under the rocker assembly on the head there is also another set of gaskets/seals that should be replaced. But I cant seem to find anyone at a parts store that knows what I'm talking about. They keep trying to sell me (and the first one got me) the gaskets that go on the valve cover. Where can i go to get the gaskets/seals that go under the rocker assembly? Much appreciate any help you can give is appreciated! |
I'm at a lost too.. which gasket you talking about? is it a cam seal? valve stem seal??
Originally Posted by droopy128
(Post 777051)
ah.. those are the lower tube seal (o-ring), it usually comes with head gasket kit, but not the valve cover kit.
ask them for the lower tube seal, between cam assembly and head, it an o-ring type. |
(Post 777054)
| All times are GMT -8. The time now is 04:24 AM. |
