Gauge swap: fuel and temp gauge stopped working
Old Jul 13, 2009 | 08:59 AM
siwel177's Avatar
Default Gauge swap: fuel and temp gauge stopped working
I swapped a gauge cluster with a tach from a 92 ex into my 92 cx and the tach and spedo are working fine, but the fuel and temp gauge show a full tank of gas and that im severely overheated
Any ideas on how to fix this?????
Old Jul 13, 2009 | 10:00 AM
Did the two gauges in the original cluster act the same way?
Old Jul 14, 2009 | 11:21 AM
siwel177's Avatar
No. I had a half tank according to the original gauge and the temp gauge worked fine.
Old Jul 14, 2009 | 11:27 AM
If you unplug the 1-wire temperature sending unit under the distributor, does the cluster temp gauge needle drop to the cold mark? If so, there's likely a short in the temp and fuel gauge circuits caused during your installation of the new cluster. Check for damaged pins in the rear cluster connectors.
Old Jul 14, 2009 | 12:27 PM
siwel177's Avatar
ok i'll check that. thanks!
Old Jul 14, 2009 | 12:49 PM
Correction: The temp gauge needle will only drop if the short is occurring between the sending unit and its connector. If the needle stays up after disconnecting the sending unit, then inspect the rear cluster connectors for damage.
Old Jul 14, 2009 | 02:15 PM
siwel177's Avatar
well i checked out the plugs in the rear of the cluster and theres no bare wiring, missing pins, or anything obviously wrong. Im not sure which plug is the temp sending unit you're talking about though. Im not so worried about the temp gauge as i am the fuel.
Old Jul 14, 2009 | 02:31 PM
When you unplugged the rear cluster connectors, did the two gauge needles drop to Empty and Cold?
Old Jul 14, 2009 | 02:33 PM
Both are important gauges that must be working. You must know whether the engine is overheating, otherwise your engine could be toast.
Old Jul 14, 2009 | 04:19 PM
siwel177's Avatar
when i turn the car off the temp gauge drops to cold, then it shoots up to hot when i turn it on. but the fuel is always saying full.
