Gear Shifting
Old Jul 25, 2008 | 12:14 PM
waseemt's Avatar
Default Gear Shifting
HI
I have Civic 1.6 Vti Prosmatic the problem which I am facing isthegear shiftingwhich very rough when ever the car shifts the gear there is a jerkand itis really very annoying. i have change the gear from Handa dealer. i also got the throttle body serviced from Handa. The person who serviced the throttle body also removed the senors from it. what i think is that he didnt installed them properly. is there any way i can have the defult settings of those senors.
Old Jul 25, 2008 | 04:31 PM
Default RE: Gear Shifting
reset your ecu to go to default basemap. the ecu will basically start over and relearn your driving style and adjust itself to where it needs to be.
http://www.c-speedracing.com/faq/02.php
i don't see the jerky shifting being related to the sensors though
Old Jul 25, 2008 | 04:40 PM
waseemt's Avatar
thanks i will try this, is there any way i can find the default setting of the two senors fitted on throttle body.
Old Jul 25, 2008 | 04:57 PM
i'm not exactly sure what you mean. what makes you think they weren't installed correctly? basically, the sensors measure whatever that particular sensor is made to measure, and sends a signal to the ecu so that the ecu knows what the sensors are reading. the sensors don't adjust, the ecu adjusts. all sensors do is send info to the ecu so the ecu knows what's going on.
if the sensors detect any problems, the ecu adjusts its settings to correct those problems. the ecu controls certain properties of the engine, such as ignition timing, and many other various settings.
Old Jul 28, 2008 | 09:39 PM
TheJGB3's Avatar
I would start by changing the trans fluid. Drain and refill with HONDA OEM ATF-Z1 fluid.
dsmoore
Mar 13, 2018 08:25 AM
tampaandy
Apr 23, 2007 07:49 PM
ajfd90
Jan 7, 2007 12:35 AM
lraicovi
Jul 27, 2005 02:29 PM
xe1002
May 24, 2005 05:49 PM
