HondaCivicForum.com
-   -   got no interior lighting (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/got-no-interior-lighting-74487/)
98civictuner Apr 1, 2009 03:44 PM
ok so I installed a tach in my car and then it all started I connected the wire to dim the light on it to my dimmer and now for some unknow reason wene I turn my lights on at night of my panel lighting goes out
vtecaddict Apr 1, 2009 04:06 PM
did you connect it to the correct dimmer wire, if you put the dimmer wire from the tach to the car dimmer ground wire, it could have shorted out the system.
addiction2bass Apr 1, 2009 04:42 PM
1 Attachment(s)
dito... i wouldnt hook up the tachs light to the dimmer switch. either wire it to the parking light wire on the switch itself or do some soldering and wire it to a dash light bulb, easiest to wire it off the back of the gauge cluster.. pull the cluster and you can see 2 black wires running from one bulb to the top small bulbs. simply tie into that wire for the tachs backlighting.
i dont remember which wire position is which so just test it with a light tester with the parking lights on.
Attachment 21079
98civictuner Apr 1, 2009 05:01 PM
damm and that crossed my mind well what can I do now i checked fuses bet they are good and the dimmer switch doesnt dim the tach anymore also
RonJ Apr 1, 2009 06:36 PM
Check whether fuse 30 under the dash is blown.
98civictuner Apr 3, 2009 09:57 AM
under the dash or under the hood?
the one under the hood is fine
mk378 Apr 3, 2009 10:08 AM
The dimmer works by controlling the ground wire from the dash lights, not the power wire. The light on an aftermarket tach can't be wired into the circuit unless it has two wires giving dedicated access to both leads of the bulb.
RonJ Apr 3, 2009 10:37 AM
Fuse 30 is under the dash. I also absolutely agree with mk378.
98civictuner Apr 3, 2009 01:13 PM
so to what can I attach the tach light to and ill check for the 30 fuse inder the dash
mk378 Apr 3, 2009 05:43 PM
Like addiction said, connect the tach light wire to the "hot" side of the dash light circuit. Then it will properly go on and off when you switch the lights on and off, though the dimmer will not dim it.
