grind going into 3rd and 4th
Old Dec 14, 2006 | 07:01 PM
bp4131017's Avatar
Default grind going into 3rd and 4th
so everytime i go into 3rd or 4th gear, it grinds...
unless i pause in nuetral and ease it in, if you go fast at all it grinds
is the linkage not tight enough or something?
Old Dec 14, 2006 | 08:38 PM
Method's Avatar
Default RE: grind going into 3rd and 4th
when was the last time you checked your tranny fluid? or changed? you shouldn't have to change it to often.
Old Dec 14, 2006 | 08:54 PM
Misha's Avatar
It's a syncro most likely. Known problem. If you don't have enough time/money to rebuild the tranny, put heavier oil there, it will will be a bit better.
Old Dec 14, 2006 | 09:26 PM
Skrapdoggydog's Avatar
yea sound like syncros, i got the same problem. hondas are notorious for this. i was told just save and get a new tranny since changing the syncros is expensive.
Old Dec 14, 2006 | 09:48 PM
mill$civic's Avatar
ya my 2nd gear does this mostly when its cold. I changed my tranny fluid to GM synchromesh and it helped alot, dont even notice it anymore
Old Dec 15, 2006 | 06:42 AM
2slo4u's Avatar
My third gear did it all the time. Really embarrassing. Makes it look like you cant find the gear. I had mine rebuilt asap. Honda charged me 350 to replace the syncros. I took the tranny itself up there. Save a little money and take it out yourself.
Old Dec 16, 2006 | 10:12 AM
bp4131017's Avatar
heavier oil as in... gear lube type stuff thats like 40w-50?
Old Dec 16, 2006 | 10:37 AM
Misha's Avatar
definitely not 40w. I believe honda recommedns smth like 10w-40 or 20w-40, so if you can find smth along those lines with last digits 50, it would be your best bet I believe. And do you know what you have there, btw? If not, that would be a good idea to start with what honda recommends
Old Dec 16, 2006 | 11:12 AM
SovXietday's Avatar
Check your motor mounts, if they're bad it likes to cause grinds like that. Simple fix and is normally overlooked. Check the rear one especially.
A synchro helps match the speeds of the transmission to the engine for each gear, if it's going bad it won't do that. A bad synchro will normally not let you shift into the next gear at high Rs, shifting will be like slamming the shifter into a wall, and then it will go in once the revs come down.
Old Dec 16, 2006 | 11:52 AM
Misha's Avatar
ORIGINAL: SovXietday
Yeah, when they wear out completely. And on civics that I happen to have, this was not that dramatic. They were/are just slowly getting worse and worse. I let it last for about 20K before I decided to drop and rebuild the tranny on my 84' (for clutch replacement), and I still have this tired syncro on my 92', and I bought this car about 60K back, and syncro was slightly bad already... I'm probably just too lazy, I don't mind waiting extra half a second when shifting into third to let the syncro do its job...
