H22 No GO
Old Nov 7, 2006 | 05:27 PM
VTECME's Avatar
Default H22 No GO
So my engine obviously has something wrong with it. It does the whole up and down idle thing while cold and if you ever give it full throttle, it will hold any rpm your at and just sit there and sputter and not stop. The only way that i can accelerate is to just barely give it any throttle and crawl up to the speed limit. Please help me!!! I installed a new primary o2 sensor and a new tps sensor. I will look at the IACV and fuel filter but haven't yet.
Old Nov 7, 2006 | 05:41 PM
Misha's Avatar
Default RE: H22 No GO
Your idle is almost sure air pocket in fast idle control vavle. The rest looks like you are running too reach. How is your mileage?
Old Nov 7, 2006 | 05:49 PM
VTECME's Avatar
definitely down from normal. I would say at least 3-5mpg less. How do i fix the idle problem first?
Old Nov 7, 2006 | 05:57 PM
Misha's Avatar
ORIGINAL: VTECME
Drain and refill your coolant, being **** about following your manual.
ORIGINAL: VTECME
One more agrument for running too reach, but I never really had honda doing this to me, so I would leave it to others to answer.
Old Nov 7, 2006 | 07:38 PM
Pete's Avatar
What kinda engine mods did you do?
Old Nov 7, 2006 | 07:56 PM
fglaustin's Avatar
what year and how many miles ???
Old Nov 7, 2006 | 08:43 PM
JDMRDCiViC95's Avatar
That happened to one of my freinds hatch when he was at a stop it would idle up to about 3 thousand and drop and go back up, and he had a new o2 sensor put in and it stoped.
Old Nov 7, 2006 | 08:45 PM
You can try adjusting your trottle body idle screw it mite be loose, that can sometimes happen.
Old Nov 7, 2006 | 08:57 PM
ef4life's Avatar
do you have the coolant lines connected to the throttle body? they will cause an idle surge if not hooked up. any CEL's? i know that same thing would happen to my car every once in a while and i would have to slowly accelerate. it threw the tps code, and the map sensor and speed sensor all at once. but that was an intermittent problem
Old Nov 7, 2006 | 09:11 PM
VTECME's Avatar
Sorry for the delay. The motor is stock the only thing that has been is the bottom portion of the intake has been removed. Everything to the TB is correctly hooked up and I took it off and cleaned while changing the tps sensor. While driving it just now, the only way to get the car to go was to just barely touch the gas pedal and shift really low. Anything over 4000rpm or so would just sit there and studder.
shortkix
EG Swaps
Oct 9, 2007 02:47 PM
XCM828
EK Swaps
20
Aug 23, 2006 08:43 PM
NTX
Nov 16, 2004 01:23 AM
superflycivic
EG Swaps
Oct 26, 2004 06:52 PM
6thgencupe
May 7, 2004 09:24 AM
