Hard shifting.
Old Apr 26, 2007 | 04:01 PM
Drunkgoose's Avatar
Default Hard shifting.
So recently my car has started being a bitch to shift... the worst is shifting into 2nd gear... I have to give it so much force, and i can't shift fast cuz of it, theres like a 1.5-2 second delay from when i press in the clutch to when i actually manage to push it into 2nd gear, just because i have to use that much force. All the gears require some force, more than normal, but shifting into 2nd is just horrible.
So... like wtf? lol.
Anyone have any ideas, suggestions? and sorry if this is a stupid question, i'm a tech noob...
Also is bad for the car that i'm driving it like that?
Any help much appreciated.
Thanks.
*Note: It's a 2000 Civic DX, 109k miles.
Old Apr 26, 2007 | 04:02 PM
ej6buddy's Avatar
Default RE: Hard shifting.
take it to a tranny shop, let him drive it around the parking lot, and then ask him, other than that, it sounds like something is up
Old Apr 26, 2007 | 04:41 PM
INJENalltheway's Avatar
I have a friend that uses synchromesh and he says it shifts like butter. Apparently butter shifts easily.
Old Apr 26, 2007 | 04:50 PM
ej6buddy's Avatar
check under the car too see if anything is in a bind
Old Apr 26, 2007 | 06:16 PM
dudes96's Avatar
maybe your clutch is going. mine started out not bad and the more i drove it the worse it got. to the point where i had to turn the car off to put it in gear it was bad.
Old Apr 26, 2007 | 06:49 PM
the_turtle's Avatar
and try changing your fluid...but i would just change it all.
Old Apr 27, 2007 | 07:31 AM
sickdancy's Avatar
the same thing happened to me....and im pretty sure that if it was shifting pretty well before and now its getting harder to that its a lubrication issue (i could be wrong), but usually in hondas the exhuast is right below the shifter brushing and stuff, and it tends to dry it out.....so u just need to lubricate it up and u should A-ok....i stand to be corrected, it just sounds like what happend to me last summer
Old Apr 27, 2007 | 11:53 AM
ic892003's Avatar
try changing the fluid and lubricating the shifter busings under the car, im having somewhat of the same problem but not as bad, im changing my fluid this week ill let u ne wat happens
Old Apr 27, 2007 | 12:41 PM
tha_next_Kobe's Avatar
try lubricating the folcrum ball joint as well...sometimes if it's dry it becomes difficult to move...i just lubed up mine and it is shifting a lot better, just some grease was all that i needed to smooth out the shifts
z_dizzlemang
Apr 25, 2008 07:52 AM
classiccarsrule85
Jan 10, 2007 10:23 AM
goof41
Sep 10, 2006 12:50 AM
jmonkie
Oct 2, 2005 08:55 AM
troutman
Aug 27, 2005 12:45 PM
