Hard to spin motor by hand
Old Nov 18, 2017 | 03:05 AM
Geo1's Avatar
Default Hard to spin motor by hand
Hello all, working on a 00 Civic, been sitting a while, friend said it died,ok, right off it sounds strange cranking over, straining, checked timing belt,ok, pulled plugs,ok, put ratchet to crank bolt and had to really pull to spin motor,oil is good, radiator has coolant,what could be the resistance,thanks
Old Nov 18, 2017 | 04:04 AM
Geo1's Avatar
So taking it apart,I can barely move the cam gear with a wrench,I figured with timing belt still on,I could load the belt each way a bit,cam bearing seizure?lost the oil pump?it just stalled,they tried to start it, cranked but no go,I figured,no fuel or spark,all fluids are clean and full, including the auto tranny, strange
Old Nov 18, 2017 | 04:48 AM
Geo1's Avatar
Ok ,seized alternator,spins fine now, but no spark, where do I start,thanks
Old Nov 20, 2017 | 02:44 PM
udraft's Avatar
Start with the primary ignition (12v).Then check cap and rotor, then check secondary (high v).
MooseOfReason
Nov 17, 2010 03:15 AM
BCivic93
Dec 1, 2007 08:00 PM
b8teen
12
Sep 5, 2006 11:35 PM
randocsmith
Jul 8, 2005 05:53 PM
Amanda
Feb 11, 2005 12:50 PM
