Head Gasket question
Old Aug 8, 2012 | 10:43 AM
mtns1234's Avatar
Default Head Gasket question
I purchased a Felpro set. I see some people recommend a three part gasket. Head will go to shop for test and surface. Also I see old and new torque specs. Any advice would be appreciated.
Old Aug 8, 2012 | 11:08 AM
What's the question?
Old Aug 8, 2012 | 11:36 AM
mtns1234's Avatar
My Fel-pro gasket is a graphic, Fel-pro also makes a 3 ply #9123PT. Is one better than the other, and is there a different torque spec for each?
Old Aug 8, 2012 | 12:38 PM
Not sure of torque specs, but I would highly suggest getting the 3 layered gasket. The layers actually crush onto eachother to make a better seal. OEM is a 3 layer, too.
Are you planning on re-using the stock head bolts?
Old Aug 8, 2012 | 01:33 PM
mtns1234's Avatar
What is a new style MLS gasket, see link below.
Honda Civic Engine >> CYLINDER HEAD GASKET LEAK ON 1988-95 CIVIC ENGINES
Old Aug 8, 2012 | 01:43 PM
mtns1234's Avatar
That is your opinion on reusing bolts. Found ebay bolts for $38.00, what do you think?
Honda CRX Civic / Delsol 1.6L SOHC Cylinder Head Bolts | eBay
Old Aug 8, 2012 | 02:52 PM
In a stock setup it is OK to re-use the stock bolts, that is probably preferable to no-name ebay bolts. The torque spec is based on the strength of the bolts; the type of gasket wouldn't matter.
Old Aug 9, 2012 | 05:34 AM
For bolts, OEM or ARP only.
Old Aug 10, 2012 | 09:10 AM
mtns1234's Avatar
Thanks for your advice.
slade8
Dec 6, 2009 06:23 PM
Crispy1
Apr 11, 2009 08:44 AM
95lsvtec
Feb 14, 2006 11:46 PM
civicpimpinsc
Feb 1, 2006 10:36 AM
civicpimpinsc
Jan 7, 2006 07:58 PM
