Headlight help
Old Jun 19, 2008 | 05:21 PM
Aleksa's Avatar
Default Headlight help
Hey guys i have a problem with my 1995 honda civic. My right front headlight doesn't work properly and only the parker light and high beam light works but not the normal beam. I went out and bought a new bulb as i thought that was the problem and when i put it in it was the same problem, only the parker light and high beam work. What confuses me is that the high beam and normal beam are on the same bulb but only the high beam works.Anyhelp wouldbegreatly appriciated. thanks....
Old Jun 19, 2008 | 05:35 PM
Default RE: Headlight help
High beams and normal beams are on separate circuits. Check whether fuse 21 or 22 is blown.
Old Jun 19, 2008 | 05:38 PM
import tuner's Avatar
It could be a wiring problem, or It could be a blown fuse. I'm nearly positive this diagram also works for 95 civics, but if it doesn't, just look in your manual. Acording to this it should be fuse 21.
Old Jun 19, 2008 | 05:53 PM
Aleksa's Avatar
Hey thanks for that it worked great. I should of checked that first. It turned out that i didn't even have a fuse in the Right headlight low beam spot....
brokenarmboy19
Jan 15, 2007 06:31 PM
rmiller28
Jul 31, 2006 08:18 PM
m00chness
Jul 18, 2006 08:54 PM
civic90power
Jun 12, 2006 06:12 PM
dj_ipirate
Oct 31, 2005 09:12 AM
