Heat controls
hey so i recently bought a 95 civic hatchback, im doing an auto-manuel conversion and have recently decided to start this! however; my heat will not work, the AC works and everything, the blower is working! it is just cold air coming out of my vents! any help would be greatly appreciated! thank you
Check that the heater hoses under the hood are hooked up. If the heater core is leaky someone may have disconnected it. If hoses are in place check that the control valve on the firewall opens and closes when you move the lever from hot to cold.
ill try it and let you no if it helps
