Help! 200$ 92 Si Hatch, no fuel pump, main relay goes bizzerk!
Old Dec 14, 2011 | 07:23 AM
Mcgarvie's Avatar
intake manifold bracket rub on the harness? that was the problem for something messing up on my old ek, does that happen on these?
Old Dec 14, 2011 | 07:24 AM
Mcgarvie's Avatar
435000kms lol
Old Dec 14, 2011 | 08:52 AM
Mcgarvie's Avatar
sorry for so many posts.. few memory cells. heres a better description i think, put the battery in. turn key on. CEL comes on for 2 seconds an goes off, no battery light, oil prs light, an brk light is on. ( no brakes ) no fuel pump but relay clicks properly. go to start an the relay behind the dash is rapidly clicking, slowing down then everything resets, dash comes back bright, CEL for 2, it goes off, an so on an so forth....
Old Dec 14, 2011 | 09:53 AM
The battery light not coming on is probably because one of the fuses is blown. It's on a different fuse than the CEL, oil, and brake warning lights. Also I think when that circuit is out the engine will not run.
Failing to crank and having the voltage drop really sounds like your battery is no good or there is a bad connection. Measure the voltage at the battery while trying to start. You have an electrical problem, it's necessary to measure some voltages and quit guessing.
Old Dec 14, 2011 | 10:01 AM
Mcgarvie's Avatar
what should it read at the battery when i go to crank it?
Old Dec 14, 2011 | 12:54 PM
More than 9 volts while cranking. Should be more than 12 volts when not cranking.
Old Dec 14, 2011 | 02:30 PM
Mcgarvie's Avatar
changed the starter and it cranks again, same old though, 9.50-10.20 volts when cranking
ktorres1120
Sep 4, 2013 08:07 PM
edmaxx
33
Jun 28, 2010 03:27 PM
Justin13
49
Feb 15, 2009 10:23 AM
n8te81
Feb 27, 2008 06:26 PM
tlkolrod
Oct 4, 2007 06:26 PM
