HELP on 2000 civic si
Old Mar 2, 2006 | 02:55 PM
DrewBoySi's Avatar
Default HELP on 2000 civic si
Hey i'm new to this site and I was just wondering if anyone has ever had a problem with their civic si? I bought the car from this guy in Austin, Texas and its a sweet car and all. It was in mint condition with 26,750 miles on it. Its a 2000 so the guy never drove it anywhere. Just to work. The problem i'm having on my car is that when the car is idle, the temperature will go up. It 'll go all the way up to the redline. Can anyone help me? I already changed the termastat on it. HELP ME PLEASE???
Old Mar 2, 2006 | 02:58 PM
Remmy's Avatar
Default RE: HELP on 2000 civic si
Have you checked the fluids? It ould be as simple as that.
Welcome by the way... I have moved this to a better area.
Old Mar 2, 2006 | 04:07 PM
DrewBoySi's Avatar
Yea, I did an oil change, oil filter change, washer fluid, coolant, the whole tune-up...
Old Mar 2, 2006 | 04:15 PM
AgentofDarkness's Avatar
Sure you didn't put the thermostat in backwards? If the thermostat is installed correctly and you have changed the fluids, it should run correctly. Unless of course, your fan isn't turning on. Drive on the highway, if your car doesn't heat up on the highway then look into the fan.
Old Mar 2, 2006 | 04:28 PM
DrewBoySi's Avatar
Yea, my uncle changed the termastat. The fan turns on but it still heats up...
Old Mar 2, 2006 | 04:32 PM
I'm thinking that there is a coolant block somewhere. The reason an engine will heat up is because the coolant is not flowing or the fan isn't running. Are you sure that the water pump is pushing the fluid around? The flow could be stopped if there is a block or if the pump isn't pushing the fluid around. Is there any smoke?
Old Mar 2, 2006 | 04:39 PM
mill$civic's Avatar
blow head gaskit?...but i think that would be kind of impossible for the amount of miles on it, worth giving it a check tho if your running out of coolent fast and tail pipe is smoking alot
Old Mar 2, 2006 | 04:52 PM
Compression test can tell you if there is a blown head gasket. The comp should be the same in all of the cylinders (160+ i believe).
Old Mar 2, 2006 | 05:48 PM
silverbullet's Avatar
I had a buddy with the same problem in a '99 SI. He replaced the thermostat and it turned out to be his water pump. He replaced that and everything worked fine.
Old Mar 2, 2006 | 09:48 PM
sacicons's Avatar
check the fuse for the fan. its in the underhood fusebox. make sure the fan is running when its hot. not the heater fan either, the one on the radiator.
